View the thread, titled "Heating setting works but not hot water setting" which is posted in Gaining Plumbing Experience on UK Plumbers Forums.
J
Jeremy
a couple of weeks ago the hot water setting on the central heating system stopped working. The only way to get hot water was to either use the electric immersion heater or have the whole central heating system on.
A defective programmer was disagnosed as the problem (an elderly Horstmann) and this has nw been replaced by a Drayton. However the issue still persisits. The boiler doesn't fire up on the hot water setting but works fine on the heating setting (which also heats the water). I'm baffled (doesn't take much!) any ideas what is the cause?
Thanks.
Jeremy
Thanks for nthe quick response. It was an electrician recomended by the recommended plumber!
Do yoiu know where am I likely to find the motorised valve and is it difficult to test?
Jeremy
Reply to the thread, titled "Heating setting works but not hot water setting" which is posted in Gaining Plumbing Experience on Plumbers Forums.
