View the thread, titled "Heating side problems with Ferroli F24 combi" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Afternoon all,
My Ferroli F24 is playing up on the heating side (HW is fine); the boiler will not ignite for CH despite the room stat calling for it; I've had a good look at it, and when I disconnect the electrical connection to the flow sensor on the CH outlet pipe and call for heating, the boiler fires...but then goes out after 10 seconds or so.
I installed a new flow sensor on the CH flow pipe and this has made no difference.
Any ideas?
SO, to reiterate, HW fine, but when CH is called for, it will not ignite boiler UNLESS CH flow sensor is disconnected, in which case it does fire, but then goes out after 10 seconds...incidentally, when it does fire up (ie with CH flow sensor disconnected), there is no electrical signal sent to the pump, so it doesn't spin.
What's the next step other than a new boiler 'cos it's doing my head in!!
Cheers
Gareth
Get a professional in.
This plumbing forum will not provide advice to anybody with regards to boiler repairs or any other form of gas plumbing without you first providing us with your Gas Safe Registration number in a thread - for very obvious reasons. If you're not qualified to touch gas, you should stay well clear of trying to!
Reply to the thread, titled "Heating side problems with Ferroli F24 combi" which is posted in UK Plumbers Forums on Electricians Forums.
