sebastienj
I have recently moved into a new flat where I can only get the heating to work with programmer. In order to heat the water in the cylinder I have to use the leaver on the hot water valve and set it to manual. I I leave it to automatic and try to start it with the programmer, the boiler does not start. The programmer is a CP715.
I have also put together a table with how things are connected
https://docs.google.com/document/d/1IGnXbrCUVCH2xI4xt7CA0iuIkjKft2ju8TiSa3Fbiwk/edit?usp=sharing
This document shows a diagram how things should be connected
(page2 - Fully Pumped System, Two 2 ports valves zone, ... - bottom right)
I have not been able to post 2 different links on the same page so I have put it at the end of the document table here:
When i connect all parts following the table I have put together I get to the same outcome shown on the diagram.
I have already replaced the hot water valve thinking it was broken but the problem remains.
Can someone help? Have made a mistake? Do i need to alter one of the connections?
It'd be nice to always have hot water... 🙂
Many thanks
Seb
Many thanks
Seb
