I
IrishThai
Hi🙂 New to forum,have replaced 80% of the plumbing system in the house over the last year it's a 3 bedroom with big single storey extension on side , fully working Baxi Bermuda back boiler )old but working well so no I won't replace till it goes😀,9 radiators, 1 bathroom , 1 downstairs shower basin and WC.New Hot water tank , pump , motor valve, all radiators (3) in extension replaced as well as all pipework, all rads removed & flushed in extising house system pressure tested using air comp to 6 bar and no leaks system then wet checked and working for 4 months no leaks or problems loads of hot water and all rads heat up fine and too hot too touch😱.
All working fine till flushed system out prior to putting corrosion inhibitor and now the downstairs does not heat up. have bled all the rads, water flows freely and is clean.tried to bleed system by open the drain valves at each end of the system till hot water flows which does occur but once valves shut the rads dont heat up.Confused.com is an understatement😕.
have read many posts and heeded replies saying what is fitted etc etc
