C
chusselb
I have a Heatline C24 boiler which is not working. It is at a tenants house and was serviced in the last 3months and was working fine till they went away for the weekend. On returning they boiler was not working. Having a look myself the boiler is acting as if there was no power to it. There is no C/H or DHW, the boiler makes no attempt to fire or make any noise. The only thing showing on the boiler is the power light, no fault light or any other indication. The pressure is at 1.5 and I have checked the PCB and the two fuses I can see are fine!
So now I'm turning to you guys for help, I suspect your going to say it's the PCB, but I have my fingers crossed you have some trick up your sleeve!!
Many thanks :smilewinkgrin:
