M
mark1981
Dear fellow members,
I hope one of you can help clear up a problem I am experiencing with my Heatline c28 boiler. When the CH setting on the boiler is set to approximately 40-50 degrees, everything works fine. We have central heating, we have hot water.
However, when the CH dial on the boiler is set to anything hotter than 40-50 we cannot get any hot water when the CH is on even if the DHW dial is set to maximum. The boiler does not kick in when the hot water taps or shower is switched on.
There are no flashing warning signs on the boiler so everything it's nothing obvious.
Any idea what the problem may be? Ideally we'd like the radiators to be hotter than they are so the house warms up quicker but we'd obviously like hot water at the same time
Mark
Mark
