View the thread, titled "Heatline s24 Boiler Drain" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hello to one and all,
First post here and guess what ,it's a problem question ,anyway.
I have been experiencing of late a fluctuation in hot water temperature on my Heatline s24 Compact,it is going from hot to cold whenever the hot tap is activated,in 30 to 60 second intervels.
After a bit of research it seems to need the Secondary Heat Exchanger cleaning which i am confident of doing myself,but in order to get access i need to drain the Boiler water system right ,but the burning question is ?How do i do this on my Boiler type.
Thanks for any replies in advance.
Only one little problem to take the case off you need to be gas safe reg, which I don't think you are
Please read the rules to the forum and the law regarding non gas safe people touching gas appliances
Ah, ifonlyicould, it's a case (get it) of onlyyoucant.
Get a gsr, after all your diagnosis may be incorrect.
Reply to the thread, titled "Heatline s24 Boiler Drain" which is posted in Boiler Advice Forum on Plumbers Forums.
