G
gazza1988
Hi guys I hope you can help me (well it's my sister) she has had 4 different plumbers and heating engineers out to it all saying something different.
The problem is the boilers fires for around a minute then stops for a minute then kicks up again then stops (this carries on for a while) also when calling for hot water it has started sounding like a small aircraft is flying above the house.
On a good day she can get hot rads upstairs but not down. Although recently she cant get hot rads because the boiler wont kick up long enough to heat the water (now its getting colder I presume)
The first engineer said it was a "dodgy bend" (a joint on a corner, I'm not hugely plumbing literate so I'll explain the best I can) so he replaced the joint and it didn't work he then rang his mate who came out and said it needed flushing. He came round and flushed each rad in turn outside with a hosepipe (I have seen this mentioned on the net) that didn't work.
Another heating engineer came out and said it could be the pump (due to the "aeroplane" noise when calling for hot water) he got a pump and then decided it wasn't that after taking the old pump out and he sent the pump he got back to supplier and didn't charge my sister for his mis-diagnosis
Another heating engineer came out and decided it needed powerflushing and would cost £950. She didn't have enough money for that and is now stuck
A british gas engineer came out and decided that a power flush wouldn't do anything and she needed BG to install a new boiler for her for £2000 (on that pay monthly deal they are running, but she didn't have a good enough credit rating)
My dad managed to get in touch with a plumber he used to work on a site with and he came to have a look for free. He said BG was wrong and the boiler needs "de-sludging" or "de-scaling" I'm not sure which one it is (or if they both the same) but he told my dad we can do it cheaply ourselve with some "sentinel x800" however I have looked around and that only works with a power flush machine (as is my understanding) and she cant afford to rent one.
Does anybody have any tips on what can be done. She has a 6 month old baby and is currently on maternity pay so money is tight. She is having to live with friends and family for obvious reasons, so if anybody wants to help her out with some (hopefully cheap :wink5🙂 solutions that would help her would be greatly appreciated (she's tried winning the lottery too and that so far has not worked :tongue🙂
