View the thread, titled "Heatline Vizio 24" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
Mark raig
Ive been asked to have a look at a heatline Vizo 24 Combi. The problem is an intermittent fault on the DHW system. Ive tried the fault finding section in the manual. The flow lts \ min is fine though the presure seems rather low the 3 way valve is operating as it should when it works which leaves according to the manual the PCB or the flow switch is there anyway of testing or fooling the board to think the flow switch is working so I can eliminate at least one or the other regards
Mark
Mark
is it a diaprahm flow switch with 2 wires?
No its got 3 wires going to it or i would have linked them together
and you have checked other things like thermistor, comb door off,re airswitch blocked plate heat?by f;ow switch do you mean dhw flow switch?or main?if dhw does the switch glow red when working?
Hi Mate yes the red led comes on when the boiler works otherwise it fails to light the ch side works fine. I have a feeling that the cold water pressure is lowish but Ive checked the flow rate with a weir gauge and it was well over minimum requirements. I meant the dhw flow switch sensor on the right hand side of the combi
if the dhw switch is constantly glowing red when the dhw is running rule it out,its not the problem,re-look at airswitch,tubing,venturies, then check dhw thermistor,if this draws a blank plate heat also when you run the dhw does flow pipe get v hot? you may need heating off to check if this is the case flow group/diverter is knackered or plate heat is blocked check all of these before condemning the pcb
120 quid just priced one
The problem is that sometimes it works sometimes it dosnt when it does work the light comes on when it dosnt work the light stops off it dosnt mater if the boiler is set to ch mode or dhw only it wouldnt be so bad if it was constant the fans noisy as well and it needs a new PRV as well triewd to tell the customer a new boliler woud be a better option there over 300 quids worth of parts before you start
The hot water switch is a turbine type with a hall effect pickup magnet so hard to test i had to go out to one when there was a lot of water demand on the street the turbine would not move after 6.30 hot water was fine again.
Hello just been out to the boiler again the system pressure was low as i topped it up the hot water tap was opened and the pressure started to drop again from reading various other threads it looks like the expansion vessel could be knackered as well then dosnt it?
cheers in advance for your help
Mark
PCB heatline vizo 24 £234.70 @hrpc not cheap
Get rid of it nothing but trouble
asked to look at one recently , it worked for an hour a day then switched off , found it to be a blocked heat exchanger , customer bought another boiler !
Reply to the thread, titled "Heatline Vizio 24" which is posted in UK Plumbers Forums on Plumbers Forums.
