View the thread, titled "hello fellow tradesfolk" which is posted in The Welcome Wagon :) on UK Plumbers Forums.
jammydodger
hi peeps this is my first ever thread ever wow pressure .i read some of ya forums n found sum interesting stuff?sum borin lol. anyways a guy from gs technical told me its ok to have flexible connection on a hob? is he right? is it just flued appliances that have to have rigid pipe connection? no mi n it was'nt a braided tap connector.
Welcome to Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK!
Hi jammydodger and welcome to UKPlumbersForums.co.uk!
Hi jammydodger
Welcome to the forums
Answer to your question....No
If the hob it set into a normal fixed worktop then it should have rigid pipework connecting to it with a gas isolation valve and you are not allowed to fit a flexible gas/cooker hose to it and gas safe would not say you could
As for the braided tap connector.... yeh...... right
was this gas safe techie on the good stuff? no way can you have a flexible connection on a hob rigid pipework only
Hobs can be fitted in with a cooker hose if it is approved by the manufacturer.
A hose cannot be fitted however where an oven is fitted below the hob. It must be rigid piped
The hose must not be fitted where it may be subject to temperature exceeding 70 deg, or be subject to abrasion (from drawers etc).
Although it may be allowed it is certainly not good practice and remember the cooker hose must be fitted to the hose manufactures instructions ie hang down in a U shape.
Reply to the thread, titled "hello fellow tradesfolk" which is posted in The Welcome Wagon :) on Plumbers Forums.
