Davedon
Hi there,
thanks for taking the time to read this, and hopefully help.
i moved into a new (old) house last year, and we have a central heating system which appears to have been fitted in 2008. It comprises...
Potterton Suprima HE (70) Boiler
Green wilo gold 60 pump
honeywell motorised valve
Potterton EP2002 time switch
Gravity fed indirect HW tank with thermostat
10 radiators with old-ish TRVs
there is no room thermostat. So from my limited knowledge, we have an unvented system with indirect gravity fed hot water? is this not unusual? I have just been hit with a hefty bill for winter usage. I know that the house is draughty etc and i am upgrading insulation and windows at the moment but I would like some advice about a more efficient way to operate the system.
1) as we have no room thermostat, the heating is either On or OFF. The TRVs are useless for accurate temp control. Do you think a wireless room stat would be a sensible addition to our system? How easy is this to install? We have a boiler interlock that switches the demand on and off with the timer.
2) it seems that we can only get CH when the HW switch is on as well. Is this a fault or just the way our system is installed? Just a bit annoying when you need an hour of heat at night but no need for hot water.
3) the boiler has a separate thermostat. I know this will not have a great effect on the radiator temp, but is there a sensible setting to get efficient use from a condensing boiler?
4) I have to top up the water in the system every week or so. I just noticed a small leak on the joint between the HW thermostat and the HW tank. It looks small, but could this cause the boiler to lose say 0.75-1 PSI per week?
I would appreciate any advice you can pass on,
many thanks,
dave
many thanks,
dave
