View the thread, titled "Help - Advice on reloacating w/c waste pipe" which is posted in UK Plumbers Forums on UK Plumbers Forums.
darrena
Hi
I am about to fit a concealed cistern in our downstairs cloakroom.
As we need to make the most of what is a pretty small room we have purchased a compact unit that only requires 8cm clearance.
The w/c in this room has a waste which goes down in to the concrete floor and off to one side to join up with the main waste pipe which is in a cavity in the wall next to the cloakroom.
to optimise the use of the compact cistern the waste pipe will need to move back about 4 inches in to the wall cavity. To do so I will need to chisel the concrete floor up and slightly amend the direction of the waste pipe. I appreciate to most this is a big job for a small gain but I just wanted to check that there isn't any reason why I should proceed with this job that I haven't thought of apart from the overall effort!
All hot and cold water supplies come from above and from what I can see the radiator pipe are in the wall cavities.
The pipe turns horizontally about 25cm down
The house is 14 years old
Thanks in advance for your help
Yes, it's a good idea to move it and make more space. In fact, it looks like it may pass right under where you need it.
Otherwise, it's chisel up a large hole and move with bends etc. On a relatively new house, it shouldn't be that hard!!
Reply to the thread, titled "Help - Advice on reloacating w/c waste pipe" which is posted in UK Plumbers Forums on Electricians Forums.
