View the thread, titled "Help! Any ideas how to level this corner basin?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hello, I’ve fitted loads of wall hung basins in my time but this one is defeating me.
Whatever I do the front of the basin is much lower than the back and I can’t get it level. It’s and Ideal Standard basin with a vanity unity that goes underneath so it needs to be level. I’ve tried corner brackets, rag bolts, shimming the brackets and wall but unless I hold the front up by hand then it sinks at the front and won’t stay level so I can’t even silicone it in place.
Any ideas or suggestions would be greatly appreciated as I’m slowly loosing it!
If it was raised a few mil off the grout line, would you be able to tell? (I mean someone other than you, you'll always know!)
Yes I could, although the fixings for the vanity unit have already been drilled as they were pretty specific on the height. I know the sealant will hide a bit of the grout line but the front of the sink is about 20mm lower than the back which seems quite a lot to me.
Can you use tile adhesive to pack it out and somehow support it until the adhesive sets? Then tighten the nuts?
Trouble is this may result in a slight gap between the side of the unit and the wall nearer the front corners of the basin.
Take the two bolted on brackets off and lengthen the slots with a file, drill, dremel or whatever to give you more vertical adjustment as they appear to be at the end of their travel.
Looks like you only need a few extra mm (thickness of grout line) of adjustment to be able to level it.
Either that or reposition those brackets upwards by the correct distance using the two unused screw holes instead of the single large bolt.
I'd personally wouldnt of used the wall brackets you have very little movement then if your walls are slightly out of plumb it will throw the basin out , you maybe better to fit the unit first then silicone the corner basin in place once cured you could nip up up the bolts slightly ? If the basin doesn't sit on the unit then remove the wall brackets silicone the basin to the wall resting on the bolts leave the nuts and plastic washers loose prop the front of the basin with tile batten on each corner level it and leave to cure , nip up once cured you will need a plastic packer to pull up against the tile possibly? Regards kop
Put a screw in the corner fixing before you finally tighten the Fischers up.
The basin will be slightly tapered on the sides, so it will release from the mould.
The Fischers will be pushing the basin up as the washers tighten down on the taper
Reply to the thread, titled "Help! Any ideas how to level this corner basin?" which is posted in UK Plumbers Forums on Electricians Forums.
