C
consumer1
Hi all, i have a Biasi 24s combi boiler and it is not firing up and heating my water or radiators. Can anyone give me any instructions of what to do to srt this out please?
Here is the scenario:
Any ideas would be most welcome,
Thank you.
- The system was working until this morning when i woke up, and was in timer mode. Up to this point radiators came on and water would heat up when you turn on the hot tap.
- I turned whole unit off for 5 mins and back on again, but still not working.
- I turned the isolator switch (screw) to increase bar pressure from 1 to 2.5 (and thought best to stop there),- made no difference.
- Put the unit into continuous (non-timer) mode, and unit makes the usual whirring noise, but pilot light not firing up in small window. Heating not coming on; water freezing cold.
- Small green light is on as usual.
- The red light (next to manual start/reset button) is off-as it has been when it was working, so i assume this is correct.
- Main gas supply is on (checked by turning on cooker hobs and they ignite)
Thank you.
