J
John H
Hi i need some advice, i have just had my Baxi Bermuda back boiler serviced, and the engineer after sericing the unit switched on the fire and done a test with a smoke stick and said the flue was not venting. He left the fire on for at least ten mins and tried the test again several times, then said there is a problem with the flue and switched every thing off and put a condemned notice on the fire.
The engineer said i could either get the flue replaced or have a new boiler fitted, which would probably be better as the back boiler i have is nearly 30 yrs old. The problem i have is that he said about fitting the new boiler in the LOFT ?, which seemed very odd as the houses next door either side have had new boilers fitted in their airing cupboard where the imersion tank was. i have mobility problems so the loft idea would cause me problems.
Any advice gratefully received.
Cheers John.
Cheers John.
