View the thread, titled "Help! I need a partial bath tap replacement" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hello,
First of all please excuse my limited knowledge on plumbing!
so my bath tap has started dripping from the ceramic cartridge, It is a single lever bath/shower mixer tap. (See photo)
I have replaced the mixer cartridge with a new one but the sealing face for the cartridge is corroded and I believe is not creating a good seal, hence the drip.
I want to replace the tap but due to the position of it, I would have to remove the entire bath to access the upright spouts.
My question is, can I replace the part of the tap connected to the spouts and if so can any one recommend a suitable replacement?
The gap between the spouts is 150mm.
If you need any more info, please ask as I want to make the correct purchase first time.
Many thanks
Leo
You could leave the tails/spouts in the bath and renew the top part. What size looking down on your tap are the centre to centre of the tap/spouts at the back? Is there a makers name on the tap? Do you have a combi boiler or just gravity hot water?
Bit hard to measure centre to centre at the back because they are oval shaped but sum where between 180-185mm (thats between the spouts mating with the bath). Between the spouts connecting to the tap is 150mm. Unfortunately no markings on the tap for identification and I have a combi boiler.
Many thanks
Like this measurement bottom image. If that is the same you could have a thermostatic bath shower mixer or a tap that connects the same as yours.
  • grohe-eurostyle-cosmopolitan-single-lever-bath-shower-mixer-33612002-spare-parts-[2]-122593-1-p.jpg
Yes the measurements in that picture are correct. Do you have any suggestions on where to get the tap from? All my searches from suppliers have failed to provide dimensions on their taps. Ideally I would like to just replace the tap for a like for like but I can’t find one 🤦🏻
Do you know where your bathroom came from? If you do you will be able to buy the same. Take a photo. You said you bought the cartridge for the tap. Did they know what the tap was? I will take a proper look when I get in.
Amazon normally have decent pictures of there sizes
Cheap and cheerful
Decent
As an Amazon Associate we earn from qualifying purchases.
Cheap and cheerful
Decent
I didn’t even think to look on amazon for a bath tap! Those dimensions seem to match up with mine, so guessing they should fit. I’ll give the cheap and cheerful one a go and easy enough to return if it doesn’t.
Thanks for all your help everyone 👍🏻
Reply to the thread, titled "Help! I need a partial bath tap replacement" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
Joined
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Unsolved
Thread Tags
LReece88,
LReece88,
