L
lame plumber
been trying to get this blighter working!
called out recently, only firing on low rate with lot of woomping noise and as soon as it tries to go to high rate cuts out on F2 fault. 3 years old and been fine to date
So:
checked ionisation sensor wiring has continuity back to pcb.
checked condensate trap clear and running ok
checked all flue seals ok
then started thinking, 200v dc to gas valve, valve opening ok in low rate, ideal techies say faulty gas valve. So one new valve later and having cured the new!! ignition fault got the same issues all over again. All ideal say is the ionisation/falme sensor faulty, so new one in post!!
Anyone else had this one and what cured it, according to ideal, they dont get this problem normally!!!!!!!!!!!!!!!!!!!!!!!!
cheers lads, thinking caps on,
So:
