View the thread, titled "HELP! Ideal mini C-24 hot water problem" which is posted in Bathroom Advice on UK Plumbers Forums.
A
alexz
Hi, guys
Need urgent help with my Ideal mini C-24 boiler which is 5 years old.
While ago problem started, I had two boiler engeneers look at it, but they couldn't find fault.😱
Here is the problem :
Hot water temperature is very low. When heating is off and hot water on boiler is firing on for 20 seconds, then off for 20 seconds, then on again, etc.
When CH is on - same story but with intervals of about 25-30 seconds and water temperature bit higher.
If hot water tap is not opened fully, I can get constant warm (not hot) water.But when CH is on pressure rising constantly (in 1-2 hours to 3 bar), so I have to bleed nearest radiator.
All boiler lights indicate normal work.
Please, if anyone can help me to distinguish the problem, you can save whole family.😱
Regards
Reply to the thread, titled "HELP! Ideal mini C-24 hot water problem" which is posted in Bathroom Advice on Plumbers Forums.
