View the thread, titled "Help! Linking gas Aga style stove to gas system boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
J
JJone
Hi, brand new to the forum. This is literally my first week in business being self employed and this is my very first job! Could have been easier haha!
Spoke to the customer on the phone, going to look at the job tomorrow.
Current setup: Gas fired Aga stove doing h/w & c/h (16 rads & 2 zones underfloor heating), customer is saying its unreliable and has had an engineer out but hasn't been sorted.
Whats required: Customer wants new Worcester greenstar system boiler installed to do the h/w & c/h and have the Aga still in place to use as a cooker and as a back up in case the boiler breaks down.
Can this be done? And how? My initial thoughts were to advise him to ditch having the cooker as a back up and just use it as a standalone cooker (blank the flow & return) but I understand that they need to at least be linked to h/w? Is this right?
So I was thinking perhaps put a twin coil cylinder in, link the Aga to the smaller coil and blank the flow and return from the c/h side? Or do I need to go down the route of installing a neutraliser? Also looked at h2 panels, are the ok to use for 2 gas fired appliances?
Also do I need to take any extra precautions due to there being underfloor heating?
I've had a lot of experience installing c/h systems but virtually none in linking systems together.
Thanks for any help in advance!
Ps My gas safe number is 547820 (not sure if I'm meant to put this here)
send your details, gs number and name etc., to gas man via pm to get access to the gs only part of the forum. oh and welcome along.
Thermal store would probably be a good bet as the heat from the AGA could be used for the heating circuit too.
Agas dont do central heating, only rayburns can do this. a properly serviced rayburn will cope easily with the above set up and if it isnt working then putting on a new boiler wont solve the problems found with a poorly designed system. Similarly with esse's and stanleys. sounds like the whole system needs looking at first, rather than changing a heat source at large expense.
first thing id do is read ther aga's instructions.
A thermal store would be a good idea if possible.
welcome to the forum.
Reply to the thread, titled "Help! Linking gas Aga style stove to gas system boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
