Hi guys, am in need of some help. I have checked all the posts on kettling and am not sure if this is my problem.
A couple of months ago, i replaced a radiator for an old dear who had gone on holiday and found one of her rooms was soaked through. It turned out, that the radiator had a pin hole leak in it. Where it had rusted.
So, i drained the system down, and fitted a new one. Then, trying to fill the open vented system back up was a nightmare. I put my hose onto a drain valve on rad and connected it to the out side tap and put the 3 port valve in manual and proceeded to fill. There were 2 air vents on top of the flow and return pipes. Manual ones, and so i twisted these open and was only able to get water to come out of one of them.
I had left it filling for around 15 minutes and still didnt get any water out of the one aav. But it came out of the f and e.
When i turned the boiler on, she said that the noise it was making wasnt there before. So i just bled the rads and left it running and it disappeared.it Was quiet.
Well today the lady knocked on my door and said that her boiler is making a loud noise.
Is this because it is built up with sludge?
Could i turn the pump upto 3?
Or should i drain down and refill?
Or get the boiler looked at by a gas engineer.
Or maybe even just add a chemical to it
How can i tell if its blocked using a magnet?
How can i tell if the system is not totally filled up with water?
Any help will be much appreciated.
Regards
Mutley
Regards
Mutley
