Not often I'll ask for help but this one has stumped me. Working on a house with a combi-boiler system for a friend. Why do these things always happen when you do work for friends?
Simple job or so I thought, move the plumbing for the washing machine to the other side of the sink. Moved waste pipe easily. Drained down the cold system (and the hot as I had to remove a hot feed for the old machine too). Ran new pipework, filled and tested system. All good apart from one small problem - no hot water...
I've checked the combi-boiler. Water is definitely running to the boiler and all taps (hot and cold) are free of airlocks, i.e. water seems to flow smoothly.
The heating still works but not the hot water. Heating pressure is 1.2 bars at cold. I looked around the house and I can see potential airlock problems: -
1.) In the loft the riser mains still runs up to the loft before running 5 metres across the loft then back down around 2 metres to the boiler.
2.) The hot water pipework runs from the boiler up 3 feet or so prior to going straight through a wall then down around 2 feet under the floor on the other side (a cupboard).
Both of these would definitely airlock on a low pressure system. On a high pressure system could this be the problem? Is it possible that an airlock can allow a good flow to the taps but prevent the boiler from warming the water? The water does cycle from luke warm to cold so the boiler is trying to heat it but is cycling for whatever reason and never really getting warm.
A faulty diverter valve seems unlikely as the boiler worked fine before this draindown.
I could really use some advice from someone with more knowledge than I as this is a friend's house and I am feeling really bad right now, even though I know it's nothing I've directly done.
