View the thread, titled "Help, New Boiler or Fix" which is posted in Boiler Advice Forum on UK Plumbers Forums.
M
Mantishead
Hello,
I own a 4 bedroom student flat which has 8 radiators. Room sizes are reasonably sizeable but I am unsure as the exact BTU calculation.
The central heating system currently has a Worcester 230 boiler which is quite old, but I understand has been serviced. The boiler is frequently overheating and cutting out. It requires an hour to recover and then it can be used again.
My letting manager, also a gas engineer, has said it may be fixed though he believes it would eventually break, possibly quite quickly. He has suggested replacing the boiler entirely and has quotes £1400. When asked how much a so called temporary fix would be, he suggested around half.
I spoke with another engineer who suggested another option of a Biasi boiler with a total cost including installation of £700. Though this seemed very low indeed.
Finally I spoke with another firm who recommended a Baxi boiler, at a cost of around £500. They recommended an engineer who then said they wouldn't use anything other than Worcester. They also suggested the £700 would certainly not be satisfactory.
I feel like I am being given the complete run-around. My gut is telling me that £1200 - £1400 is probably the target budget, though I would like to know which boiler to go for and more importantly can I trust the engineer. Should I be asking for warranties, parts and labour etc.
Thanks for any help in this area..
Personally where I am £1500-2000 is about the average for a combi swap, the Worcester 230 is a discontinued product and although the spares will still be stocked by merchants your in all fairness probably better off with a new SEDBUK 'A' rated energy efficient combi which could save you money on your gas bill rather than sticking with your SEDBUK 'G' rated unit.
Worcester for worcester isnt a bad swap installer wise if you pick a Worcester accredited installer, as he will probably have experience of the 230, also you will get a longer period of guarantee with a WAI plumber.
My personal favourite boilers at the moment are the Alpha CDC and Baxi Duotec Platinum both come with 5 year guarantees and give great flowrates on HW and arent a pain in the rse to fit.
Happy hunting
It's not up to a tenant to install or service a boiler. That's the landlord's responsiblity. The tenant is only liable for the energy used (gas in this case) so it's in the tenant's interest to have an efficient and well serviced boiler.
I must admit I only found this out a few weeks ago.
get a baxi duotec or if you want cheaper and more reliable a potterton performa from a landlords point of view,its reliable,works well and parts are reasonable and readily available, about £1000-£1250 depending on whats involved the output of the boiler needed they come in 24_30 kw but the prices quoted are in wales so may vary district to district
Reply to the thread, titled "Help, New Boiler or Fix" which is posted in Boiler Advice Forum on Plumbers Forums.
