View the thread, titled "Help, part or info needed!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
A
Alleycat
Hi there, my boiler recently broke down and me and my family are left without hot water and heating. I had a look at my boiler and found out its an old glow worm space saver 38.
The spare part i need is called a 'Spark Generator' and i'm wondering if anyone knows anything that can fit into this, or find the part i need. The G C number is 41.315.44 if that helps. Whilst the actual spark generator is a C 8/97 if that helps too.
Thanks in advance.
Thanks in advance.
An RGi would haVe to fit and he would tell you.
I know where the fault is, and which part needs replacing i just need to know where to get one as i can't find anything useful on google.
Thanks for the reply anyway 🙂
as said above you need an rgi to do it for you, he will supply it and make sure your boiler is safe afterwards. not a job i will give you any advice for i'm afraid, imagine if you install it yourself and in any way change the function of your boiler with possibly very bad outcome.
shaun
Reply to the thread, titled "Help, part or info needed!" which is posted in UK Plumbers Forums on Plumbers Forums.
