L
les luchini
Evening all,
I have a Potterton Performa 28, 95% plumbed with JG Speedfit the system is 8 years old. Over the past few weeks the system has been losing pressure, done the usual of checking the rads for corrosion, rad valves all ok, lifted the inspection hatches and checked the manifolds all ok. no visible water marks on ceilings however their was black water mark stains in the downstaires hallway leading to a shower room. the flooring is weyroc throughout the house. I remember Teeing off the hall rad to feed the shower room other than these two Tee offs there are no more joins between the manifolds and the rads. So cut a channel in the weyroc
1ft x 8ft found nothing polystirene and plastic underneath also dry.
Boiler loosing between .5 and .75 of pressure overnight. filled the system again this morning 1.5 bar by mid afternoon had dropped to 1.2 bar the heating was not on. Help!!!!!!!!!!!!! new carpets coming on wednesday.🙁
