bob the plumber
hoping one of you more experienced lads can help! My breakdown knowledge is basic but im trying to help a friend out whos short on a few pennies.
I am GSR
Ravenheat CSI 85 does not fire on demand for hw and ch
pressure is fine
power is fine
gas present
engineer light turns on when there is demand or ch/hw
pump runs
no 230v to fan?
got back to the overheat stat which i believe is causing the problem
I switched the cables on the overheat stat which made the fan run so i know the fan works
however as daft as this sounds am i correct in saying that the air pressure switch will only operate when the fan operates?
how do i check that the pressure switch is operating as it should
and how do i know for a fact that the overheat stat is deffo to blame?
thanks for your patience and time, they dont teach you so much breakdown stuff at college and all i do all day long is install after install with oil, gas boilers and bathrooms so i dont get much chance to get involved in the breakdwn side and im just wanting to learn, good opportunity on my friends boiler 🙂
thanks
bob
I am GSR
pressure is fine
power is fine
gas present
pump runs
no 230v to fan?
thanks
bob
