View the thread, titled "Help - potterton powermax HE boiler problems" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Steve100
Anyone know how to stop the pressure from going up and then going to lock out on this potterton powermax HE boiler? It has a error message of E 0.1
Any suggestions grateful.
The pressure gauge cuts out at 4.
filling loop valve is passing, pressure is too high, should be 1 bar when cold, drop system pressure, boiler should fire, check filling loop valve and check valve.
next check the expansion vessel, has not de-pressurized or split, if de-pressurized top up to 1 bar, if split either change or install a separate vessel on the system pipe-work
Reply to the thread, titled "Help - potterton powermax HE boiler problems" which is posted in Boiler Advice Forum on Plumbers Forums.
