J
johnbhoy
Hi.
First off I'm not a plumber, this is a diy project so go easy😱
I'm fitting a new shower for my mother and got it connected up ok but soon noticed a leak dripping down the wall cavity. The pipe is 8mm copper and goes from the bathroom shower up into the attic were its connected to the bathroom water supply which is 15mm copper. The 8mm copper pipe running from shower to water connection is about 5m in length with no joints, it's just bent into place. I took it out to investigate the leak and it's burst where it was situated halfway up the wall cavity.
Would I be ok to re pipe it using 15mm speedfit grey pipe and could I run it for the complete 5m with possibly 1 elbow joint in it?
Also are copper compression fittings ok the use with this?
PS. Am I right in saying 8mm copper is quite unusual for a shower? It's an old house
