View the thread, titled "Help... underfloor heating" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi, can any one give any advice on UFH please? We have a system that goes through one pump, picture attached, and there is no way of switching the UFH off whilst the downstairs heating is on, despite it being on a separate thermostat.
When I turn the thermostat for the UFH something in the boiler kicks into life but it seems to have no effect on the UFH being on or off.
The reason I ask is I need to switch it off as we have just had wood floor fit and knocked through to the conservatory, so half the room now has UFH and half hasn't and I fear one side will expand more than the other and buckle.
A plumber has been and has turned off two isolator valves with a screwdriver out of shot to the left, and that has made two of the grey pipes cold, but the others are still warm.
I've turned the pump down to setting 1, and closed the red mixing(?) valve at the top, but not sure it's shut down the UFH or not. It's very difficult to tell as there is wood on top of tiles, plus I'm paranoid!
I could do with someone labeling with pipe might be doing what!
Thanks in advance!
disconnect the power to the pump/ controls or if your confident to do so drain down and cap the unwanted circuits.
Reply to the thread, titled "Help... underfloor heating" which is posted in UK Plumbers Forums on Plumbers Forums.
