A
antych
I'm renovating my bathroom and want a better showering solution (there was an electric shower installed by previous owner, fed from the mains).
From what I've read I have a pretty standard gravity system, with a cold water tank in the loft and a heater in a cupboard. It looks like I will have to install a pump to have a proper shower, but there's something I don't understand and hopefully someone can explain. Cold water has such a poor pressure that if I lift the shower head above my head it stops running. Hot water on the other hand, seems to flow just fine and it seem to have higher pressure in taps as well.
If I understood this correctly, water heater is fed from the gravity tank just like cold water taps. Shouldn't cold and hot water have the same pressure then?
Even when I raise the shower head, it's still about a meter below the water tank. Shouldn't cold water still run? (we already checked if the pipes are blocked)
Does it have anything to do, with cold water going into toilet, or hot water being mixed with cold mains water in the kitchen tap?
Carl
Carl
