View the thread, titled "HELP! - WARM/HOT water coming from the COLD tap?" which is posted in Plumbing Advice for Any Other Country on UK Plumbers Forums.
Hello🙂
For no apparent reason the cold water has stop running from the Taps in the bathroom (both sink and bathtub) the loo won't refill either. The Cold tap in the kitchen sink is Fine with both pressure and cold temperature. The HOT water taps seem to be working fine from both Kitchen and Bathroom....
It seemed pretty weird how this problem happened, then I remember I turned all the radiators off and left 1 on about 3-4 days ago so I turned them all back ON...THEN the loo began to refill and when I tried the bathroom COLD tap....WARM/HOT water started running from them....???
I left them on for 15 minutes and now they have run dry again with nothing coming from the COLD taps in the Bathroom...
FINALLY - I have seperate hot & cold taps...And 30 minutes before the problem we had our annual service boiler inspection carried out by British gas!!
Thoughts anyone?😕
Very much appreciated.
Mark.
what type of boiler system do you have ?
apart from that it don't make any sense as the radiators don't have nothing to do with the taps in any way.
Upvote 0
Yes... Very weird!
Check your cold water tank (in loft?) if your system has one. Could be that it is empty due to a seized ball valve on the supply into the tank. This would dry up all taps that are supplied from this tank.
If your hot water cylinder (if you have one!) is also supplied from this tank, the hot water too should dry up -- but it hasn't -- so as I say, weird! Maybe the hot water will stop running but only after a delay (as the pipework empties)?
But do check the cw tank/cistern!
Upvote 0
Its possible you have got yourself an air blockage.
If you have had the heating on and the cold pipes where not full due to the block then its possible that heat from your hot water pipes has been able to heat up some of the water in your cold pipe as the usual volume is depleted. Even worse if the cold pipe is above the hot (which it should not be) that would heat the cold even more. Just a possible !
Suggest you check start at the top of the system and work your way down i.e cold water cistern in loft is full, ball cock free and outlet not blocked by anything horrible if you an't got a byelaw 30 kit on it.
Hope you resolve it.
Cheers ears Spindle.
Upvote 0
has a bathroom been fitted the reason i ask is with you saying no cold water only and HW is ok, there is no chance that somone could of tap into your CH thinking its CW by mistake especially with you saying it ran for 15 mins and then stop this is about the same time it would take for the heating system to drain down and how it didnt work until yu turn the radiators on and it would explain warm water coming from taps and then stopin until the system has refilled
Upvote 0
Reply to the thread, titled "HELP! - WARM/HOT water coming from the COLD tap?" which is posted in Plumbing Advice for Any Other Country on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Unsolved
[email protected],
stevetheplumber,
