No. You're doing more harm than good. If it's a sealed system is shouldn't need draining until the boiler is next replaced. It won't hurt to check the inhibitor concentration once in a while, say every 5 years, but if it's a sealed system that isn't leaking and hence being topped up frequently even this is probably unnecessary.Hi all I normally drain my system down every November and then refill and add an inhibitor.
Is it a good idea
I think it depends on the cleaner. Sentinel says X400 can be left in for un unlimited time, but I can't see why you'd want to!Adding cleaner even worse as its a right pain to get all of it out, except with a powerflush (which is a days work in itself) it will eat your system.
