View the thread, titled "Help with downstairs wc connection" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
T
turbo
Hi all , can anybody help with this ? We have an extention on th eside of the house which is built on a raft and we want to put a utility room in th emiddle of the extention. The only way I can see of running the soil pipe is along the top of the slab and then out the wall and in to the stack at the bottom, there would be a enough fall on the 3 meters from the wc to the bottom of the stack as the floor over the slab is the be raised slightly.Ther will be another 2 ast floor batrooms also being connect to the same stack. Is this all OK to do? Thanks
Hi turbo
from what you say and misstyped words excepted, I would say that it sounds feasible
as this is a new extension has the building work already been done and if so did you have the rooms fitted out?
you can put this request to any competent plumber who will give you the yay or nay based on actual site conditions, to put it another way you are not making a stupid or silly request
I hope this helps
Russ
Reply to the thread, titled "Help with downstairs wc connection" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
