A
annabella
🙁Hello, This is my first time on the forum and being a female without knowing much about plumbing I hope that someone can help with some advice I have a Triton Electric T80si shower which has worked well then suddenly was only luke warm. I have now found that if I run the hot water from the bath tap then the shower becomes hot. The shower is a direct feed from the mains, although running bath water doesn't seem to reduce flow much as it was never brilliant but ok.
Any idea's would be gratefully received, many thanks Annabella
