If you turn both both on yes
Like I said the heating is not on but the the radiators are hot? ThanksIf you turn both both on yes
No have a F&E tank in the loft and its a Honeywell 2 port valve.Are you sure it was a 2 port? Are you on a Gravity hot water system?
Never had a problem until this two port valve head was fitted. Thanks for answeringNo that’s not right
F&E are for heating systems, not hot water. Can you post a photo of cylinder cupboard and wiring center with wiring shown?No have a F&E tank in the loft and its a Honeywell 2 port valve.
Reply to the thread, titled "Help with two port valve head" which is posted in UK Plumbers Forums on Electricians Forums.
