Thanks. I’ve tried that already.That pipe is solvent welded, cannot undo.
Use a flexible drain cleaning wire.
Rothenberger Pipe And Drain Cleaning Coil
The Rothenberger pipe and drain cleaning coil is a simple and effective tool. Use it to unblock pipes, kitchen sinks, wash basins, baths and shower wastes. All you need to do is pop it into the blocked drain, manoeuvre it along to the blockage and, with a few clockwise turns of the handle, it'll...www.toolstation.com
Rothenberger Corded drain coil, (L)1370mm
Pipe and drain cleaning coil with brush for easy cleaning of kitchen sinks, wash basins or bathtubs, this pipe drain cleaning coil from Rothenberger is a must have purchase for any DIY tool kit.www.diy.com
Where does it run to and how long is the pipe runI have tried to unblock my bathroom sink and managed to undo the u bend pipe and clear any blockage inside.
But there is still a blockage in the pipe leading out of the wall but I can’t see anyway to undo this section. Please advise ASAP. Thank you.
Reply to the thread, titled "Help with under bathroom sink pipe work" which is posted in UK Plumbers Forums on Plumbers Forums.
