View the thread, titled "help" which is posted in UK Plumbers Forums on UK Plumbers Forums.
A
adriana
Hi. we have a valliant premium turbo gas water heater which is going to replace an old valliant with single pipe etc. When connecting the cold water, is it the connection on the right as you look at it thats the cold water supply? also when its all connected, should it start automatically when the power is turned on? there is only a single on off switch !
Check with your registered gas installer who has to remove your old gas water heater, to be on the safe side
Reply to the thread, titled "help" which is posted in UK Plumbers Forums on Plumbers Forums.
