View the thread, titled "Hi all, Aquastream shower removal.. HELP" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
L
lcjohno
Hi all plumbers, first time on this forum, i use the tilers forum quite alot but have been directed here for answers to my problem below.
I am supposed to be tiling a shower tomo but having problems getting the Aquastream shower off the wall. The only thing holding it in place are the pipes going straight into it. There is a hot and cold pipe that are pushed in a plastic fitting and i cant release them. They come straight through the wall and into the shower. I've looked on the internet and seen that there should be a special tool in the shower cover to release these but there's not on this one. Is there any one else who has had this problem and is there a way round it without a special tool? Help needed ASAP, supposed to be doing this tomo and if i cant get the shower off i'm going to be sat at home all day doing jack.
Any help would be much much appreciated
Lee​
are the fittings pushfit? can you see a ring that moves when you try to remove the pipes, if so what i use is a flat head screwdriver to hold the ring in when i pull the pipe out do a bit on one then on the other then go back to the first keep doing this until the pipes are released.
I'm sure there pushfit and i know the ring you mean but it doesnt seem to move at all. I've had a go doing it like you said but its like the shower wont budge off the pipes.
Reply to the thread, titled "Hi all, Aquastream shower removal.. HELP" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
