Welcome to Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK!
Welcome to UKPlumbersForums.co.uk Worcester Bosch. Thanks for introducing yourself.
hi am just about to change my own boiler(g rated)and have considered the glow worm 15hx due it only needs a 15mm supply
but also looked at the 15ri but see this needs a 22mm supply is this correct
pipe sizing is based on the size of appliances and distance from the meter. get an rgi in to appraise your needs, just cos a boiler has a 15mm inlet doesnt mean you can run the whole supply to it in 15mm pipe
Hi, this is Worcester, Bosch Group
We would like to help with any Worcester related advice via our technical help team (Tel 0844 892 3366), our website or this forum.
Our website (Boilers and renewable energy home heating products - Worcester, Bosch Group UK homeowner site) contains a host of technical information, FAQ's, literature downloads and many other helpful solutions.
We look forward to helping you.
Welcome to the forum,look forward to your input 🙂
i am an rgi but orig iron is under tiled floor so unable to tell how far it runs before going 15mm that feeds my current potterton
only 2 appliances are boiler and hob
if i have to i will run new 22 from meter but would rther not as say what you will 22mm horizontal external pipe is ugly
Our technical department can help you with this enquiry.
Please email them directly [email protected] and they'll repsond to your query.
Hope this helps
