View the thread, titled "high CO reading on worcester 28i rsf boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
M
mahogany
hi there, mahogany new member to this site. getting high CO reading on Worcester 28i rsf Gc no 47 311 54 burner pressures ok gas rate fine removed burner,removed heat exchanger removed and washed through fins ,took out fan, checked flue all ok.spoke to Worcester technical who said it must be the gas valve.replaced gas valve still the same over 700ppm CO any help very much appreciated gas safe registered
You will have to up your number of posts and apply the get on the GSR forum before you can get advice on gas issues.
Reply to the thread, titled "high CO reading on worcester 28i rsf boiler" which is posted in Boiler Advice Forum on Electricians Forums.
