Hmm!
Might get a bit of noise or possibly wear in the coil. Which seems obvious.
Have a look at the max recommended pressures of any fittings in or on the system.
Ask yourself "What is the maximum pressure those basin, bath, sink unit taps or shower will work at?"
"What is the max pressure for the pipe fittings"
"What is the max head for the heat store" and so on.
Look for the weakest lowest pressure link in the system and if its within bounds leave alone, if its not, use a pressure reducer.
Then consider, do you really need all that pressure?
Does more pressure help wear things out faster?
It sure can make things noisier and what may seem obvious cause pipe wall erosion. I am sure if I was a pipe wall, I would prefer you pressing against me at 3 bar than 4.5.
What is the maximum recommended speed of water in a system?
Go to "Copperclub" and have look at their recommendations. They are the Copper Development Association who represent the makers of most of the copper stuff we use.
If they don't know we might as well go home 🙂
Admittedly it may all be BS info, but its free and saves buying the BS stuff.
But if your in a geek mood, go to the library and ask to see the relevant BS documents. You can find out which ones they are by looking in the installation manual for the heat store.
That way you get the genuine info.
Possibly a bit of water hammer as well.
If I am putting you off, I don't intend too. I am just trying to point you to where you can find out what you want.
From my own rule of thumb, I would say its probably okay but perhaps noisy and does wear things a bit. And usually if a washer starts to wear water hammer can make a bang like a bomb or start that maddening buzzing. But it probably makes you renew the washers faster.
The other side of things, is that its great to have a tap that probably delivers somewhere near its max and with all that pressure you can probably have more than one tap on at once and still have good pressure. Not only that, you can use as many elbows as you want and the furthest away fittings get a bit of water as well.
Not a very scientific way to think of things though and having loads of elbows is not recommended.
Good Fortune
