View the thread, titled "Honeywell 3 Way Motorised Valve" which is posted in UK Plumbers Forums on UK Plumbers Forums.
J
Jim Cooper
Advice please.
I have a Honeywell 3 way valve 40003916 -003., which when CH & HW are called for at the same time, from the programmer, Only HW will kick in. Once the water has reached its required temperature, the Heating will come on.
Individually, CH & HW works O.K.
Can anyone offer any advice? Could it be a sticky valve ? or is it electric connections?
R
Jim
its made to give priority to hot water
it is made to give priority to hot water why not fit s plan with two zone valves then it will work the way you want it to
Thanks for reply David, but I thought I have got a 'Y' plan that should allow for CH & HW to be called for at the same time.
Is mine a 'W' plan?
R
Jim
Reply to the thread, titled "Honeywell 3 Way Motorised Valve" which is posted in UK Plumbers Forums on Plumbers Forums.
