I Have a Honeywell 3 way power head that the motor seems to have died, my question is can the power head be replaced on this particular model or will i need to change the whole valve?
Not that i can see, but i don't think its a pre 1985 model although i could be wrong.
Easy way to confirm is there 4 screws or two screws holding the silver box onto the brass body
4 screws have to change whole valve eg drain down
2 screws just head
2 screws just head
Thanks Shaun,
Ill have to look when I'm back home as i cant see from the photos I've got on me.
I'm really hoping i don't have to drain down as i want a quick fix! I'm also hoping it is actually the motor.. it heats the hot water tank but wont heat the rads but i could get over it by pushing and holding the lever towards manual side and after a few grinding buzzing noises it would eventually click over and then the boiler would boost up and heat the rads??
