View the thread, titled "Honeywell DT90E room thermostat" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I have just bought a Honeywell DT90E room thermostat to replace a faulty Heatmiser DS1. I have a Honeywell ST9400c programmer and Honeywell Mid Position Valve. I have read on several forums that the DT90E should be wired LIVE to A, SWITCHED LIVE to B, C is not used and Neutral wire is not used. I have tested my DT90E with a continuity tester and when I adjust the temperature to match the room temperature (or lower) the meter shows that A is switching to C. Surely this means that the SWITCHED LIVE should be connected to C?
Will switch to B or C depending if you want the stat to operate on temp rise, or fall
Reply to the thread, titled "Honeywell DT90E room thermostat" which is posted in UK Plumbers Forums on Electricians Forums.
