M
MikeJJJ
Can anyone help please? I am a reasonably competent DIYer and have a small project I think I could handle.
My central heating controller has failed and I'd like to fit a replacement. The current system is a Honeywell Smartfit low voltage controller which drives a Vaillant Ecoflex Plus boiler. I am minded to go smart with a Honeywell Evohome controller. The zone valves are being replaced next week with 240v ones and while the system is drained down I will replace some of the TRVs to take the Honeywell heads.
The system is S Plan and I plan to use BDR1 relays and a HW pack to control the MVs.
My question is: How do I get the hot water demand to the boiler? Currently the Smartfit system is connected with a 4 core cable (3 + earth) which carries 240v ELN and a BLACK wire which connects the SL Smartfit terminal to connector 4 on the boiler. Logically I'd guess that the ORANGE wires from the MVs should go to terminal 4 on the boiler. (Vaillant unhelpfully only use numbers) Is this correct or will I need to use another BDR1 relay to switch the boiler?
