View the thread, titled "Honeywell ST699 thermostat upgrade.." which is posted in UK Plumbers Forums on UK Plumbers Forums.
I have a fairly old Honeywell ST699 thermostat that controls the central heating and hot water on a Worcester boiler. It is in an old farmhouse which has an airing cupboard with a hot water tank. There is also a separate thermostat located near the top of the stairwell.
I'd like to upgrade it to a wireless thermostat if possible and was wondering if anyone has replaced this model. I have fitted a Nest unit before, however this was on a combi boiler and I'm not sure how straight forward replacing this unit is going to be.
Any advice greatly appreciated.
Rob
Yes can be changed the reciever would go in the airing cupboard/ where the tank is normally as the heating wiring centre is there
Will require re wiring / adjusting as you don’t have a timer / room stat any more unless you want the nest dial where the room stat is now
That's not a thermostat, it's a programmer, i.e. a time clock. You can replace the heating timer by using a programmable thermostat (which is goodness in itself as you can make it choose different temperatures at different times of the day) but you'll still need some sort of timeswitch to control the hot water. You can get single channel ones though.
Graham (Not a qualified plumber, but I've done this myself)
Reply to the thread, titled "Honeywell ST699 thermostat upgrade.." which is posted in UK Plumbers Forums on Electricians Forums.
