View the thread, titled "Honeywell" which is posted in UK Plumbers Forums on UK Plumbers Forums.
buckley plumb
Did a boiler swap sat and wired s plan. I bought the honeywell easy wiring centre to make things easy. I cut links 2 and 4 but hw zone valve would open on htg demand had me puzzled for a while. The instructions on the lid of wiring centre were not clear. In small print it says cut link 1 if using programmer. One to watch for
I had the same issue. Instructions are naff
All I had with mine was sticker in lid. What made it a little harder was the s plan kit was drayton. Good job they use same numbers on room Stat
The salus centre is not bad larger than standard 10 way and you just link out the terminals with wire links
only way I can do it is to follow the sequence of events needed for everything to work ok, seems to work first time then 🙂
Surprises me in this day and age that something of a proper plug and play nature hasn't come out.
Ha ha never come across them before. Considering its Honeywell the pack isn't actually that expensive. Found for £180
I do if its existing. If it's brand new I do myself
Reply to the thread, titled "Honeywell" which is posted in UK Plumbers Forums on Plumbers Forums.
