View the thread, titled "Hot and cold connected the wrong way round on a 3 way shower valve" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
dancypo
Hi, I'm new to the forum, i really need some help, i had a GR-AZ-34C high quality BRASS body cartridge in-wall thermostatic concealed valve shower mixer faucet fitted and the plumber has attached the hot and cold backwards, so, i only get freezing or boiling water!!!
Is it possible to turn the thermostat cartridge round to avoid having to smash off the tiles and switch the pipoework?
Thanks very much, the plumber knows what has happened and is now bumping my calls, he was supposed to be round yesterday but didn't turn up
Thanks you
Dan
Do you have the Manufacturers instructions?
Is this the valve?
Hi and thanks for the reply, yes that looks like the valve, the thermostat has GUOREN written on it, i have the instructions but it doesn't mention the hot and cold connected the wrong way round or spinning the thermostat.
Thanks again
Dan
As far as I am aware there is no way of correcting the incorrectly piped hot and cold supply without switching the pipes over. Where do the pipes enter the wall from? Do they drop inside the wall from the ceiling/ loft above? Or perhaps enter the wall below a bath or below the shower tray?
They run under a screed floor and up a concrete wall, i do however have a cupboard in the bathroom where the pipes enter the bathroom, i have a hot 22mm pipe there and a 15mm cold, could i switch the pipes there?
Thank you
Dan
If it's a screed floor then that's not too bad, break a bit of the floor up and switch there.
unfortunately the spot where the pipes enter the room under the floor is right under a freestanding bath, i suppose i could whip the bath off and do it there, pain in the arse but it would solve the bath and shower in one go
Dan
Is the cold fed by the cold main and the hot water gravity fed? If so they could be the right way round but the cold main pressure could be forcing the hot back.
Is your w/c in the bathroom?
If not then I would go with altering the pipe work in the cupboard and switching the basin hot/cold around behind the pedestal, probably less work then taking the floor up.
Its really not upto you though if you have already paid someone to do it in the first place! Get the original plumber back to sort as the shower is useless at the moment!
Paid for work completed but he was supposed to come back for a second fix, once i told him of the problem its all gone silent
Thanks for your help
Dan
Agreed, sounds like best course of action with least disruption. Assuming we have understood your description of the pipe layout correctly.
Thanks for all your help lads, i sent a text saying id be taking him to small claims court, which i wouldn't have really bothered doing, and he finally replied blaming it on his phone being broken, obvious BS as it was ringing and texts being delivered. He's coming back tomorrow.
I have a couple of options now i think, other that ripping the tiles or floor up.
Theres a section of floor (just before you step down into the bathroom) that has yet to be tiled, i knocked up a small piece of floor and there are 4-5 (not sure how many yet as i didn't want to go too mad before i spoke to anyone) pipes running about an inch under the concrete floor, so maybe something could be done there.
or
i can remove the stand alone bath and cut a small access hole in the tiles as this wall is a stud wall and switch the pipes before it hits the bath as this would also sort the shower too.
you wouldn't be able to see the hole if cut in the right place.
Dan
Reply to the thread, titled "Hot and cold connected the wrong way round on a 3 way shower valve" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
