Hi, advice please..
Combination boiler.
Hot water to the shower is very poor.
Hot water to the bath is hot if just a very slow trickle is made
Kitchen sink is red hot so boiler is just fine..
Everything used to be fine so the pipework must be ok..
How is cold water mixing with the hot supply...
Why is the hot water cold by the time it gets to the bath or the shower.
They are normal bath taps..
The shower is separate and probably thermostatic..
Can the shower be causing this?
Might there be a one way valve that is broken?
Combination boiler so hot and cold should be at the same pressure...
I'm going under the bath tomorrow to check the pipes, to see which is hot or not etc..
Anyone give me any possibilities before I turn up?
Any advise welcome...
Thanks in advance
Combination boiler.
Thanks in advance
