Mar 6, 2023
Exeter, Devon
General Plumber
Hi, I've got a cold water storage tank which feeds the hot water cylinder below. The hot water is backflowing up to the cold water tank and then overflowing now and again. If i put a non return valve on the cold feed to the cylinder would this just push the water up to the vent pipe? There are tmvs in the property so I'm thinking one is back feeding. Or maybe a split coil?
I wouldn’t be putting a check valve on the cold feed to the cylinder, you need to find out what’s passing. Have you renewed anything recently?
