Any advice would be extremely appreciated. I have an indirect heating system. A few days ago the large cold water tank overflow started to leak. Given that I had the ball-cock replaced 6 months ago I kinda knew it was not the problem - it was not.
When the water is being heated on its own it is raising the water level in the large cold water tank up to a point where it overflows down the pipe at the roof eves.
This happens over a period of a 90 mins (water is only heated for 20 mins). Having looked in the tank I can see that water is being backfilling the large cold water tank not via the open vent pipe but the pipe at the bottom of the tank where the cold water should flow to the Cylinder.
When the hot water is off (not heating water) the large cold water tank level remains as it should.
Any ideas why this is happening???? I have had no new taps or mixers installed and this has only happened (as far as I know) in the past few days
